Chủ đề: Monitor - HP w1907 gương soi
07-24-2008, 05:50 PM #1
Mua em này lâu rồi, tầm hơn 1 tháng :xauho:, nhưng lười quá hôm nay mới viết bài khoe với anh em :beerdi:
Nhật xét ban đầu khi mới cầm về nhà là rất thích thú, thay cho em SS 793DF từ bao lâu nay, vừa mất diện tích vừa tốn điện :bun:
Cảm giác chuyển từ CRT -->> LCD Wide đúng là rất khác biệt, coi phim phê lun, HD thì càng phê :votay:
Introduction
The HP Pavilion w1907 is a 19-inch wide-screen flat panel monitor with liquid crystal display (LCD) and thin-film transistor (TFT) screen. Figure 1: Photo of the HP Pavilion w1907 LCD wide-screen flat panel monitor
Product number
RK283AA
Features
The HP Pavilion w1907 LCD wide-screen flat panel monitor has the following features:- BriteView Technology enhances clarity and provides brilliant colors
- 1440 x 900 factory-set resolution
- Video inputs supported:<ul>
<li>VGA analog signal - DVI-D digital signal
</ul>
Technical specifications
LCD feature Specification Display size 19-inch (48.3 cm) diagonal and viewable image Display type Thin-Film Transistor LCD active matrix
BriteView technology Input terminal VGA 15-pin D-type connector
DVI-D connector Scanning frequency Horizontal scan range 30-83 KHz
Vertical scan range 55-75 Hz Native resolution (H x V) 1440 x 900 Contrast ratio up to 1000:1 Response time 5 ms (on-off) Pixel pitch 0.285 mm Power source - AC/DC adapter Input rating: 100 to 240V~
Power consumption: <49 W in operating mode, <2 W in sleep mode Operating environment Temperature: 32 degrees F to 104 degrees F (0 degrees C to 40 degrees C )
Humidity: 15% RH through 90% RH (non-condensing) Storage environment Temperature: -4 degrees F to 140 degrees F (-20 degrees C to 60 degrees C)
Humidity: 15% RH through 90% RH (non-condensing) Dimensions H x W x D, including base:
18.2 x 14.9 x 7.2 inches (45.2 x 37.8 x 18.2 cm) Weight Unpacked: 11 lbs (5 Kg) EMI standard FCC Class B Mounting Standard VESA 4-hole 100 mm x 100 mm EPA Energy Star As an Energy Star Partner, Hewlett-Packard has determined that this product meets the Energy Star guidelines for energy efficiency.
Phụ kiện
Mặt sau
Lắp chân đế
Input - có thêm ngõ vào cho speaker tích hợp, nghe chỉ tạm tạm thôi
Gương, soi gương
Tổng thể
So sánh kích thước với 15 wide
soi gương
nhìn trực diện
Bên trái sáng
nhìn từ trên xuống :sun:
Menu - Options
Nhận xét :
Về giá : so với mấy em tầm tầm đó như ASUS, SS hay Dell là ôn
Về design: thiết kế đẹp, gương trông rất " bóng" , vẻ ngoài hào nhoáng làm ta thích mắt, + thêm phụ kiện đi kèm là bộ treo headphone, ảnh, cắm hoa hay bút .v.v trên HP.com bán 10$ :leluoi:
chưa bao h cho cái ảnh nào lên đó để trưng ( ảnh xấu :leluoi, được cái cắm bút lông vệ sinh máy + headphone gọn gàng
Quá trình sử dụng :
- Qua thời gian cũng khá dài sử dụng thấy khá thích thú, xem phim hay pictures đều ổn, có vẻ như so sánh với LCD của laptop HP thì hơi khập khiễng chút, nhưng :
- màu sắc khi xem phim và ảnh thì tươi hơn
- màu trắng đen và tương phản của laptop lại trông thích mắt hơi, trắng của laptop là trắng sáng, trắng trong ( như quảng cáo bột giặt Tide - trắng j mà sáng thế )
- còn trắng của w1907 hơi khác chút, nhưng so với mấy em tương đương của các hãng khác thì dường như HP cho màu trắng đẹp hơn Dell, hay SS ..v.v vậy nên khi đọc báo hay soạn văn bản trông cũng thích thú hơnView more random threads:
- Dân đà nẵng vẫn thích đất nền hơn chung cư
- sửa máy làm đá viên , sửa máy làm kem tươi tại hà nội
- [KitGuru Review] ASUS GeForce GTX 970 DirectCU Mini 4GB
- [Đánh giá chi tiết] HIS AMD HD7750
- Mouse - M$ Optical Mice 500 - món quà từ xứ sở nhai trầu
- Chim giả 2 đầu 78UP cực mềm đưa cặp đồng tính đến bến bờ sung mãn nhất
- [Quick Review] ASUS Maximus VI Gene
- E8400 và P5B-Deluxe
- [Review] NZXT PHANTOM 530 và Tản Nhiệt nước Kraken X41-X61
- Khám phá card đồ họa ZOTAC GTX 860M 2GB DDR5 của máy tính mini-PC
07-24-2008, 07:12 PM #2
bị loá như vầy thì xoay màn hình ra hướng khác, chứ để thế nhìn khó chịu lắm
07-24-2008, 07:55 PM #3
chói vầy sao coi phim được nhẩy, đề nghị đổi vị trí bàn
Dáng em này nhìn đúng là sang thiệt
Cái cắm bút nhìn như comdom :them:
07-24-2008, 10:48 PM #4
Để xem cái avatar của mình được rì view thế nào? :sun:ha ha. Vẫn lăn tăn vì mua hơn 1 năm rồi mà không review cho mọi người. Nay có người làm hộ rồi.:votay:
Ủa mà đợt hàng sau này nó kèm thêm cáp dvi và một loạt các phụ kiện treo linh tinh khác nữa àh? Giá cả thế nào?:gaicam:
Check panel chưa?
Tui toàn để bút với kính lên cái chân đế:sun:
07-24-2008, 11:28 PM #5
nhìn trên menu thì thấy có mục "switch video input", tình hình là cũng muốn làm một em 19-22" mà có DVI+DSUB mà có thể switch qua lại dc giữa 2 signal vì tui muốn cắm cùng lúc con xbox với com vô. LCD Dell có tính này ko mấy bro.
07-25-2008, 12:08 AM #6
Gửi bởi tienathlon
07-25-2008, 12:45 AM #7
nhìn thèm wá chắc zá cũng cao lắm hả mí huynh
07-25-2008, 01:33 AM #8
Gửi bởi Jedi Knight
07-25-2008, 04:01 AM #9
Gửi bởi linhzin811
thế nên cũng ko để ý lắm, với lại cái bàn cứ thay đổi liên tục nên cũng ko lo lắm :sun:
07-25-2008, 06:19 AM #10
trông rất sang, nhưng em chỉ kết mấy món trang trí kia thôi :votay:
p/s: con này chơi 22" phê phải biết :do:
Bạn đang độ một trải nghiệm cực khoái khó quên, đa tầng và dị biệt? Bạn muốn khám phá cảm giác "lên đỉnh" mạnh mẽ mà không cần phải cố gắng quá nhiều? Lovense Ridge – đồ chơi mát-xa hậu môn sáng dạ...
? Lovense Ridge có tốt không? Đánh giá chi tiết từ A-Z
