Chủ đề: DriverPack Solution 11.8 Final
08-05-2011, 04:31 AM #1Junior Member
DriverPack Solution 11.8 Final - the latest version of the most popular program to automatically install drivers. This version contains a number of new features and optimized for all platforms (x86-x64), and significantly simplifies the process of reinstalling Windows on almost any computer. You will now be spared the problems of finding and installing drivers, reducing them to a few clicks!
Pros of using the interface, user-friendly and intuitive intelligent technology classification drivers several installation options (for the professional to the novice user) multilingualism (does not require linguistic knowledge and effort): English, Russian, Ukrainian, German, French, Italian, Spanish, Turkish, Azeri, Dutch, Lithuanian check the availability of new versions of software (fast and free upgrade)
Functionality DriverPack Solution 11 efficient and quick search for drivers drivers installation on virtually any computer, just a few minutes an "downgrade" from Windows Vista to Windows XP (even if the manufacturer has not posted on its website the drivers for Windows XP) search and download the missing driver from the Internet, according to set parameters of the driver Quickly update the existing set of drivers installed to more recent versions assistance in creating and using your own database driver
Key features:
Works with any driver packages (files 7z, zip), for any operating system since Windows XP
Work as a 32 bit and 64 bit under
Ability to group and custom installation of drivers
Ability to handle files in the packages finish Bashrat'a
Transparent application settings (all settings are changed through the settings). All settings are stored in an ini-file
Quickly create a database of drivers (the ability to create all databases with one click)
Friendly and responsive interface
View the list of devices for the local PC
View oxidase drivers for the driver package
Ability to work with any carrier
The ability to add and run additional programs from the interface utility (use to add menu-options - additional tools). Ie, to some extent can be used as a autorun for your collections
Check for program updates via Internet
Ability to silent install
Multilingual interface
Program benefits can be roughly put together in a group most relevant to users
1. Accessibility.
The program is free.
Moreover, unlike other "free" or shareware programs that can be downloaded (to order on the disks), without further action: enter key codes, passwords. Installed full version of the program works correctly and does not require any additional (and often very tedious) Action, for example, activation of this version.
2. Installation.
Simple, fast, secure.
The installed program will not adversely affect other applications and systems in general. Choice of modes (package) setup allows users to work with her at various levels of training.
3. Use.
Save time by an independent search and install (reinstall) the drivers.
User confidence in the system to work correctly with the new drivers.
4. Update.
The ability to automatically find and install new drivers and useful utilities.
5. Result.
Save time, effort, money and other resources.
The effective work of the computer system, no problems when installing new equipment, increasing the productivity of already installed equipment.
Filesonic.com
http://www.filesonic.com/file/1594670034/DRPSu11.8.part1.rar
http://www.filesonic.com/file/1594670024/DRPSu11.8.part2.rar
http://www.filesonic.com/file/1594670064/DRPSu11.8.part3.rar
http://www.filesonic.com/file/1594670074/DRPSu11.8.part4.rar
http://www.filesonic.com/file/1594670174/DRPSu11.8.part5.rar
http://www.filesonic.com/file/1594670184/DRPSu11.8.part6.rar
http://www.filesonic.com/file/1594670194/DRPSu11.8.part7.rar
Wupload.com
http://www.wupload.com/file/77652745/DRPSu11.8.part1.rar
http://www.wupload.com/file/77652744/DRPSu11.8.part2.rar
http://www.wupload.com/file/77654226/DRPSu11.8.part3.rar
http://www.wupload.com/file/77654225/DRPSu11.8.part4.rar
http://www.wupload.com/file/77655819/DRPSu11.8.part5.rar
http://www.wupload.com/file/77655829/DRPSu11.8.part6.rar
http://www.wupload.com/file/77656315/DRPSu11.8.part7.rar
Fileserve.com
http://www.fileserve.com/file/nxHATck/DRPSu11.8.part1.rar
http://www.fileserve.com/file/ejXeBf5/DRPSu11.8.part2.rar
http://www.fileserve.com/file/cqJbtyr/DRPSu11.8.part3.rar
http://www.fileserve.com/file/GzVUam6/DRPSu11.8.part4.rar
http://www.fileserve.com/file/jtxNg4H/DRPSu11.8.part5.rar
http://www.fileserve.com/file/nVXNeXk/DRPSu11.8.part6.rar
http://www.fileserve.com/file/XTcXVpP/DRPSu11.8.part7.rar
Uploadstation.com
http://www.uploadstation.com/file/jC9UN54/DRPSu11.8.part1.rar
http://www.uploadstation.com/file/T2p2tQX/DRPSu11.8.part2.rar
http://www.uploadstation.com/file/MD7dvTA/DRPSu11.8.part3.rar
http://www.uploadstation.com/file/aA3nndS/DRPSu11.8.part4.rar
http://www.uploadstation.com/file/hVN3JEy/DRPSu11.8.part5.rar
http://www.uploadstation.com/file/RBjWwxf/DRPSu11.8.part6.rar
http://www.uploadstation.com/file/UrUQPQW/DRPSu11.8.part7.rar
Uploading.com
http://uploading.com/files/94de18eb/DRPSu11.8.part1.rar/
http://uploading.com/files/8dc8mc16/DRPSu11.8.part2.rar/
http://uploading.com/files/f21f574a/DRPSu11.8.part3.rar/
http://uploading.com/files/856a69e2/DRPSu11.8.part4.rar/
http://uploading.com/files/d4144af4/DRPSu11.8.part5.rar/
http://uploading.com/files/3671m892/DRPSu11.8.part6.rar/
http://uploading.com/files/11b31bc7/DRPSu11.8.part7.rar/View more random threads:
- bác nào dùng main p35/p31/g33/g31 của gigabye ko?
- Realtek Driver for Vista RTM
- Xin Driver SataII của tất cả cái main hiện tại.
- Hot Driver XFi mod cho Audigy2
- Windows Vista driver for X-Plosion ^^'
- Máy cài XP nhưng mỗi lần đút USB loại mới dzô là lại đòi driver là seo ?
- Creative Audigy 2 2.05.0000 beta
- CAC BAC CHI DUM
- Driver Lan Satellite M100 for XP! Help!
- Realtek AC 97 ALC650 Audio CODECs Driver v A3.93 for Windows 98/Me/2000/XP/2003 (32/6
Điều quan trọng trong quan hệ, nam giới cần cho dương vật đi vào bao cao su nữ. một đôi người nhận thấy cảm giác ở cậu bé có vẻ hoạt động tốt phải thâm nhập sâu giữa bên ngoài bao cao su và thành âm...
Lời khuyên cho phụ nữ trước khi sử dụng bao cao su nữ
