Zip Repair is a utility that will repair corrupt Zip files.
Usually a corrupt Zip file gives the error message:
“Cannot open file: it does not appear to be a valid archive”
NEW FEATRURES:
NEW: Zip Repair will fix CRC errors in .zip files so that data can still be uncompressed
NEW: Zip Repair supports spanned zip volumes. You can now repair and extract from a spanned zip set even if part of the set is missing.
NEW: Full support for the Zip64 format
NEW: Support for huge file sizes 2GB+ (as long as you have the disk space)
http://w17.easy-share.com/1702949969.html
