12-14-2006, 07:51 AM #1
Auzentech X-Meridian 7.1 Soundcard
Sau HDA Explosion 7.1 giờ thêm con này nữa, con này dc 3dguru đánh giá khá cao đó
- The C-Media Oxygen HD CMI8788 [COLOR=#000080 ! important][COLOR=#000080 ! important]Audio
- [COLOR=#000080 ! important]Processor
- [/COLOR][/COLOR] is the heart of the AUZEN X-MERIDIAN 7.1.
- 4 pcs 24-bit/192 kHz AK4396VF (120dB-part spec.) DACs for 7.1channel output. (24-bit/192kHz in 7.1channel playback)
- 1 pc 24-bit/192kHz AK5385VF (114dB-part spec.) ADC input (24-bit/192 kHz recording)
- 1 pc CMI9780 AC'97 2.3 CODEC for AUX input, CD input, MIC input (16bit/48kHz playback/recording)
- Integrated up to 192k/24-bit S/PDIF transmitter for 44.1 kHz, 48 kHz, 96 kHz, 192 kHz SPDIF output.
- Supports onboard high grade special COAX+OPTIC combo type transmitter module for up to 192 kHz SPDIF out.
- Integrated up to 192k/24-bit S/PDIF receiver for 44.1 kHz, 48 kHz, 96 kHz, 192 kHz SPDIF input.
- Supports onboard high grade special COAX+OPTIC combo type receiver module for up to 192 kHz SPDIF input.
- Standard 10PIN Front Panel Audio supports connectivity for stereo audio output and a microphone input from most new chassis. (All 7.1channel analog output muted by jack connection sense of front panel headphone out / Dual MIC input available by back panel mic input and front panel mic input)
- DTS® Interactive - A real-time 5.1 channel encoder.
- DTS® Neo:PC - An upmix matrix technology.
- Dolby® Digital Live (DDL) - A real-time 5.1 channel encoding.
- Dolby® ProLogic IIx surround processor spreading stereo audio into 7.1 channel surround sound.
- Dolby® Headphone technology, conveying 5.1 surround and 3D gaming audio over stereo headphones.
- Dolby® Virtual Speaker solution, bringing amazing virtual surround sound fields via general two speakers.
- C-Media FlexBass™ - LFE channel crossover frequency setable from range 50 to 250Hz in Small speaker mode and Small/Large speaker selectable.
- C-Media Magic Voice™, popular feature for disguising your tone in online chatting.
- C-Media Xear 3D™ 7.1 Virtual Speaker Shifter technology.
- C-Media’s unique Karaoke functions: Microphone Echo, Key-shifting.
- 27 global reverberation environments.
- Supports most industrial standards of 3D sound for PC gaming, including EAX™ 1.0 & 2.0, A3D™ 1.0, and DirectSound™.
- Swappable DIP type OPAMP controlled preamp out circuit (4pcs output control OPAMP IC with DIY socket)
- Surface mount type OPAMP controlled preamp input circuit (2pcs input control OPAMP for ADC and 1pc MIC input gain control)
- 5Vrms (Differential DAC output with gain adjustment / approximately full swing from +/- 8V dual power supply)
- Proper OPAMP control circuit (large capacity 1A +8V, -8V, dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level.
- Upgrade Extension available (Extra 6.35mm MIC / Extra Digital I/O sold separately)
MOre detail
_http://www.guru3d.com/article/sound/399/1/
[/COLOR]View more random threads:
- First Review Intel Wolfdale(45nm) CPUs
- Apple vượt Microsoft, trở thành tập đoàn công nghệ số 1
- Đánh giá sơ bộ Zenfone Zoom về thiết kế, camera và hiệu năng
- Ấn tượng laptop Ferrari
- Digital Storm giới thiệu MTXT xm15 cho game thủ
- Intel Core i7-6700K and i5-6600K Retail Box Photos and Pricing Leak
- Toshiba Canvio 3.0 – Ổ cứng di động mới
- Máy tính bảng 7" của Sharp được bán tại Nhật cuối tháng này
- Bản Windows Phone 8.1 Lockscreen mới yêu cầu 1 GB RAM để sử dụng
- Kết quả giải “Sản Phẩm CNTT-TT Ưa Chuộng Nhất 2010”
12-14-2006, 09:32 AM #2
nhìn tụ điện thích nhỉ, ko biết bao h mình có tiền sắm con Sound Card rời để lên đời nhỉ
12-14-2006, 09:53 AM #3
- May 2016
con này tui thấy bán cũng lâu rùi, giá $199, chip này là serie sau của X Plosion
12-14-2006, 03:18 PM #4
con này xài chung chip với con wỷ gì của razer đó
thà mua con này sướng hơn, con razer thiết kế dở òm, mắc, lại chơi cái trò cạo chip để giấu tên như bọn TQ á :lele:
12-14-2006, 04:46 PM #5
con này giá đó mà thêm cái frontpanel nửa thì quá tuyệt:sun:
12-14-2006, 05:27 PM #6
Gửi bởi recoba
12-14-2006, 06:15 PM #7
em đang thắc mắc về khoản optical và coxial của nó
bt là coxial,but khi gắn thêm 2 đầu nhựa trong trong dưới dzô thì lại chuyển thành optical :-?
Gửi bởi recoba
but đảm bảo nghe tí music xong về muốn đập creative ^^'
creative tiếng vừa khô khan vừa giả tạo,mấy dòng X-fi thì chưa xài but tôi xài thử đến 2ZS pla òi
thấy thêm mỗi cí font panel là kết,còn đâu như nhau =.=
12-14-2006, 07:02 PM #8
Dàn tụ nhìn thích mắt nhỉ, giá còn hơn cả X-Fi Platinum nữa.
12-14-2006, 07:13 PM #9
Gửi bởi linhzin811
# Supports onboard high grade special COAX+OPTIC combo type transmitter module for up to 192 kHz SPDIF out.
# Supports onboard high grade special COAX+OPTIC combo type receiver module for up to 192 kHz SPDIF input.
12-14-2006, 07:46 PM #10
Gửi bởi linhzin811
chẳng wa đèn optical nó nằm trong cái đầu coaxial thôi
nếu ku có mấy cái CD player của sony (loại slim nhất á, mấy cái khác chưa có rờ nên ko bit) thì nó cũng y chang vầy: có 1 cái lỗ headphone 3ly thôi nhưng cũng có thể làm lỗ optical
hồi trc xài con main chaintech zenizth nforce3 (tên gì wên òi) cũng như vầy, lỗ optical nằm trong lỗ sub out
Giãn mao mạch, một tình trạng phổ biến của mao mạch, có thể ảnh hưởng đáng kể đến vẻ ngoài và tự tin của một người. Vì vậy, điều trị giãn mao mạch đã trở thành một giải pháp phổ biến để cải thiện...
Phục hồi da giãn mao mạch
