Kết quả 1 đến 5 của 5
    VGA Accelero S2 Cooler giải nhiệt tốt, không tiếng ồn
    The Swiss cooling solution provider – ARCTIC COOLING introduces a radically new passive cooling solution for main stream graphic cards. Without moving
    parts inside, Accelero S2 effectively helps the graphic card to remove heat and silently keeps the components cool. Thanks to the elegant design, Accelero S2 can even outperform other active cooling solutions, bringing a true industrial leading zero noise solution for demanding users.
    Radically new optimized passive design
    To provide the ultimate heat conductivity and larger surface area, Accelero S2 features dual thick copper heatpipes which extend directly from GPU core. Heat from the GPU can rapidly reach through 31 dissipating fins that extend beyond the height of the graphic card. Optimized fin design allows air flow to easily pass through and removes the heat effectively. Together with the bundled RAM heat sinks, Accelero S2 provides an all-round passive solution that achieves the best cooling performance.
    Practical zero noise solution
    Install and forget about it – No moving parts means maintenance free. An extra pair of mounting clips provides extensive protection to the graphic card that prevents damage from improper handling. With the help of the new mounting design, Accelero S2 is widely compatible with ATI (Radeon X1650, X1600, X1550, X1300, X1050, X850, X800, X700, X600, X550, X300 and 9*** series) and nVIDIA (GeForce 7600, 7300, 6600, FX 5950, FX 5900, FX 5700 (Ultra), FX 5600, FX 5500, FX 5200, 4 TI and MX series) graphic cards.
    Accelero S2 will be available by end of March 2007. The MSRP is USD 22 and Euro 18 (excl VAT).
    Source: _http://www.vr-zone.com/?i=4692
    Accelero S2 giải nhiệt tốt, ko ồn và tương thích với với hầu hết các VGA card của ATI và NVidia. Giá tương đối rẻ, khoảng $22.
    Đáng bùn là nó ko cặp kè muối mè với các dòng cao cấp đc (như G80)
    giá rẻ như vậy nhưng ko lắp được cho 1 loạt vid phổ thông hiện nay, cũng ko cool lắm
    ủa tương thích nhiều mà ISA,giá rẽ như vậy chắc hiệu năng cũng kô cao lắm đâu :gaicam:
    cái này gắn thêm quạt 92 hoặc 120 vào thì tương thiứch được tất
    vđ là vid loại mới bây giờ chỉ giải nhiệt cho mỗi gpu thôi chưa đủ , còn mấy cái tụ , mạch chỉnh nguồn nữa thì mới oc được :gaicam:
