05-11-2007, 08:54 PM #1
Radeon HD 2000 tích hợp sound card !!!
Dòng Radeon HD 2000 thật sự tích hợp cả sound card
Finally, we introduced HD 2,000 series integrations the HD audio frequency processor specification, it supports AC3 (5.1) standard Dolby Digital and the DTS code form, supports 32kHz, 44.1kHz, the 48kHz 16-bit audio frequency class, all has the very good support regarding Vista and the WinXP operating system, the audio frequency specification can meet the mainstream high clear need. It can be said that, HD 2,000 reveals the HDMI output which embraced provides already was the present relative consummation solution.
Because ATI increased the digital sound card unit in the demonstration core, therefore this is a new hardware equipment, if the user wants to use under Windows XP reveals the card integration the digital sound card, then you must install the rising tone card the actuation. Certainly ATi in entire revealed the card in the actuation package already the conformity, the user did not need to worry for this. If you use the operating system is VISTA, then has been more convenient, because VISTA system itself may distinguish the digital sound card which the HD 2,000 series reveals embraces, no longer needs the user installment actuation. Under is under Windows XP installs HD 2000 reveals when the card actuation the condition, you may see in the installation process new HD the Audio sound card to distinguish, now has obtained ATI free "bestows" the digital sound card.
HD 2,000 reveals which in the card to integrate in the digital sound card equipment name has "HDMI" marking, simultaneously its chart sign page is a dull numeral graphic display device, this number character audio equipment is when the HDMI output special-purpose. If you want to use reveal the card the HDMI output function (to add HDMI on DVI output to transform), OK, it had the use.
In the control panel chose Digital Output Device (HDMI) to take current tacitly approved the work audio equipment, by now, you all handed over here under operating system any audio frequency processing to process, when HDMI output also simultaneously has output the digital audio frequency. Connects your HDMI graphic display device, looks like HDMI the monitor, the liquid crystal, the plasma television or the back throws the television, you were allowed to enjoy the number pronunciation video frequency the high grade signal.
In Digital Output Device (HDMI) in the equipment control panel, the user may carry on some detailed hypotheses: DTS, Dolby Digital, WMA the Pro three kind of numerals audio frequency decoding, HD in 2000 integrates the digital sound card all may the good support.
http://www.hardspell.com/doc/hardware/36904_page18159.htmlView more random threads:
- Vài hình ảnh mới về bo mạch chủ Z97 Deluxe của ASUS
- Sony 'vất vả' với thị trường TV
- Loạt sản phẩm bo mạch chủ H55xx đến từ Foxconn
- Tablet 9,7 inch của HP chạy chip tốc độ 1,2 GHz
- ASUS hé lộ bo mạch chủ B85 Pro Gamer dành cho game thủ
- Nvidia ngăn chặn mod NF4U -> SLI trên mobo DFI
- Factiva - công cụ tìm kiếm chuyên về kinh doanh
- Intel dự định cho "lên đường" hàng loạt vi xử lý Ivy Bridge
- Smartphone siêu xe Lamborghini Spyder giá 1.781 USD
- Sự thật đau lòng sau 'mổ nội soi' iPad
05-11-2007, 09:12 PM #2
VGA có sound card vậy main có cần sound onbard luôn ko huynh.Nếu ta cài 2 driver main va vga nó sẽ nhận driver nào khi cả 2 đều có sound ob?
05-11-2007, 11:13 PM #3
Gửi bởi locgame
Mà chất lượng của tính hiệu digital của mọi chip xử lý âm thanh là như nhau ==> cùi bắp :lacmong:
05-12-2007, 12:42 AM #4
Gửi bởi locgame
nếu cài driver cho cả 2 thì thường chỉ sound của main là có tiếng
~> khi gắn sound rời mọi ng` thường disable cái sound của main đi ^^'
Gửi bởi NMC
hiện tại speaker cho PC hình như chưa có hãng nào support HDMI
card có HDMI ở đây để ng` dùng có thể xuất ra LCD or receiver gồm cả audio n video vs chất lượng good mà gọn gàng tiện lợi
công xinh xẻo biếu canh rỏ hiện đương là thiên hướng ấm hot tốt cạc chị em đặc bặt quan tâm và giàu nhu cầu thực hiện. Địa chỉ phẫu thuật thẩm mỹ ở đâu để nhất? với Viola – Eva tìm vào địa chỉ thấm...
Địa chỉ thẩm mỹ vùng kín uy tín an toàn tại Đà Nẵng cho các chị em làm đẹp
